Clecoed rear HS spars to Reinforcement bars. Clecoed and clamped elevator hinge bracket pieces to rear spar assembly. Drilled elevator hinge bracket assembly to size. Removed and deburred elevator hinge assembly. Cleaned and primed elevator hinge bearing flange. Reassembled and riveted elevator hinge bearing assembly.
