Soldered the limiting resistors to the LED anodes, and a scrap of red wire to the resistors. Covered the resistors and the joints with heat shrink. Soldered scraps or black wire to the LED cathodes and covered the joints with heat shrink. Supported the joints with a piece of heat shrink around both leads. Crimped D-Sub connectors on the ends of the leads. Connected the Starter Engaged lead, Fuel Pump +12v and Smoke Pump +12v leads to the sataus LEDs. Bundled three ground wires into one piggy-back PIDG connector and connected the grounds to the smoke pump ground lead.
