Neals Web Site
RV-7
Engine Case Ground
Finally decided to use the 1/4-20 hole behind the oil filler tube to secure the engine case ground. Cut the ground wire from #4 welding cable and soldered the lugs on the ends. Loosly installed the cable to check the fit.
RV-8 Home
RV-8 Home
RV-7 Home
2505
Baffles
200
Cowling
53
93
132
411
Fairings
45
80
134
538
Panel
Systems
678
