In this work session, I continued the work on the Right Fuel Tank. I used a soldering iron to uncover the top rivets from the protective blue film. I then began match drilling the fuel tank skin to the underlying structure. I then reinstalled the T-702 tank baffle to the fuel tank structure and began counter sinking the rivet holes connecting the T-701 Tank Skin to the T-702 Fuel Baffle. Finally, I removed the T-703 fuel tank baffle, positioned the T-704 Ring to place and drill the T-708 access Plate. I then removed the T-708 Access plate, and positioned, marked, and drilled T-407 Ring for the rivets that will attatch the K1000-08 Nut plates.
