The test of the NAPA 7220 primer was partially successful. We were able to get the primer on the material. However, the adhesion of the primer to the aluminum and the application of the primer were unsatisfactory.
- As such, I'm trying a new primer, Moeller Zinc Phosphate primer, an aerosol applied epoxy primer.
- To give the test a new surface I've elected to build a new practice project and apply the primer to it in a test.
- This is the construction of practice project #3.
- Also this will be the dress rehersal for trimming the skin stiffeners correctly
-- Create nice edges that only remove the corners
-- Properly taper the stiffeners to fit underneath the skin.
