Nate's RV-7 Site
Date:  9-5-2019
Number of Hours:  1.50
Manual Reference:  Sect 6-7
Brief Description:  Rudder counter balance rib and skin
I also spent a good while working on riveting the rudder counterbalance rib to the counterblance skin, without much success. I was only able to drive about two rivets correctly before giving the enitre enterprise a rest. The problem stemmed mostly from properly securing the material to the work bench, which was compounded by the lack of working space inside the rib with a bucking bar. Unfortunately a 4" yoke is needed to use the squeezer, and I only have a 3" squeezer. I almost opted for MK319BS pulled rivets but instead decided to give the attempt a rest.
