Nate's RV-7 Site
Date:  6-16-2019
Manual Reference:  Sect 6-9
Brief Description:  Right Elevator Assembly
In this log entry I record the work I accomplished riveting the right elevator. I began by using the 3x rivet gun to instal the AN470AD4-4 rivets that attached the E-703 rib to the E-704 rib. After attaching the ribs together. I then used the AN470AD4-5,-6,and -7 rivets to attach the elevator spar to the outboard and inboard hinge doublers and spar reinforcement plates and the K1000-6 Platenuts.
