Brief Description: Riveting the Vertical Stabilizer
This log entry details my work on the vertical stabilizer. I elected to cleko then rivet the vertical stabilizer structure together using the 3x rivet gun. This would assure that all of the AN470 rivets would be set correctly. I also used a flush set to install the AN426 rivets in the lower section of the aft vertical stabilizer spar. The pieces were successfully riveted together without incident. Only a few rivets needed to be replaced while attempting to set the rivets.
