Nate's RV-7 Site
Date:  2-11-2020
Number of Hours:  3.00
Manual Reference:  Sect 7-5
Brief Description:  Match Drilling Wing Skins and Leading Edge Rib
I finally completed match drilling the upper and lower kins to the left and right wing. Completing that, I match drilled the W-408-1L and -1R ribs through the spar as directed. Finally, I match drilled the Right wight inboard Z bracket through the spar.
Removed Lower Wing Skins
Match Drilled W-408-1L
Match Drilled Z-Brackets
