I started work by dimpling the rivet holes at the outer edge of the rear spars. The directions called for these holes to be counter sunk. However the material is thin enough to be dimpled. I opted for the simpler method and utilized my hand squeezer to accomplish this.
After that I went back to working on finishing the wing and leading edge ribs. This is turning out to be quite a long task. Initially it it overwhelming simply due to the size of the job, however by working on them a little everyday, I've been able to slowly work through the pile of 30 wing ribs. I still have yet to finish the additional 10 leading edge ribs, and I have yet to even start the fuel tank ribs and stiffeners. I've put that part off entirely until a later date.
