After finishing construction of the bending jig, I used double sided tape to affix it in place, then used a small piece of 2x4 and the dead blow hammer to begin the bends. Once the bend had progressed enough, I used the 2x rivet gun to complete the crease. After completing the bends on both sides of the trim tab, I refitted the trim tab spar to the skins and match drilled the spar and the trim tab horns to the trim tab.
