Nate's RV-7 Site
Date:  6-17-2019
Number of Hours:  3.00
Manual Reference:  Sect 6-9
Brief Description:  Right Elevator Assembly
In this log entry I record the work riveting the right elevator. On this date, I riveted the E-709 rib to the E-702 spar using the AN426AD3-3.5 rivets into the counter sunk holes using the 2x rivet gun and a tungsten bucking bar. After that I then riveted the WD-605-R-1 elevator horn to the E-702 spar and E-709 rib using AN470AD4-4 rivets. After that I then rivetd the E-703 and E-704 rib assembly to the E-702 rib using AN470AD4-4 rivets. One rivet did not sit well, so I removed it and installed a new rivet.
