In this log, I document the work I did on the frame of the rudder of the aircraft. After drilling the rudder stiffeners to the skin, I then fit the skins to the to the rudder frame and match drilled the skins to the rudder spar and the upper and lower ribs. I also had to use a rat tail file to slightly open the slot at the bottom of the skins to get them to properly fit over the rudder horn at the bottom of the rudder.
