I completed drilling the Right Horizontal Stab Skins to the understructure. Then disassembled the entire structure, to finish out the work necessary on the inside structire. Once the parts were disassembled I then drilled the extra holes in the HS-710, HS-714, HS-00001, and HS-702 as directed in the instruction manual.
Once the holes were drilled I then trimmed the HS-702 in accordance with DWG-3 and test fit the HS-702, HS-00001, and the HS-00005 together.
After all of the holes were drilled I began the process of deburring all of the holes in all of the components for the left and right horizontal stab.
