Brief Description: Installed oil cooler mount, cooler, plenum and cab
Installed oil cooler mount, cooler, plenum and cable. Adjusted and cut cockpit actuator cable for oil cooler plenum butterfly valve. Fabricated both inlet and outlet Aeroquip 303-8 hoses from engine to cooler and from cooler to engine. Clearance is very tight on the lower fitting, but it all works and has enough clearance. About 1/4" clearance to firewall on the lower fitting and 1/2" clearance from back of cooler to the fuel pump fitting. Good thing that I moved to a 90 degree restrictor fitting on the fuel pump - fuel pressure sender line restrictor fitting. It all just works nicely. Enough room for engine movement without touching. The prop and mixture cables do lie on top of the cooler mounting brackets, so I will leave them loose and cover the cables with tygon tubing to ensure against vibration, rubbing fatigue.
