Apply structural adhesive and tightened nuts on gear bolts to drive in the bushings. Mix thick micro-glass and add fillet around the .75” tubes between the gear saddles. Apply 6x BID over tube & fillet.
Inspect wheel bearings (they were bone-dry), lubed bearings with Aeroshell 28 and reinstalled axles and wheels.
Moved Fuse off the saw-horse and cleaned up garage to get my car back in!
