Hot-glued 1” slab of pink foam to existing open of the keep (where the elevator pushrod will exit). Trimmed with vibro-tool and sanded to final shape then covered with duct-tape. Saturated 17x7 piece of triax and same size piece of carbon between two pieces of plastic – Used a wallpaper roller to force the epoxy into the weave and roll out any extra to the edges. Trimmed the edges while still sandwiched between the plastic and allowed to set for a while before applying to the keel.
