Rough-cut 9x canard hinge 'blanks' - the piece looks like an "L" from .125" sheet stock (from Van's). Using the 1 purchaced hinge from Velocity as a template, routed addtional copies using a laminate bit mounted in the table router. Cleaned edges using bench grinder and 3M wheel.
