Continued to work the LH gear attachment. 12” 1/4” bit used. Only partially drilled through the firewall and the gear bulkhead with the 1.25” cup saw as to not lose the 1/4” pilot hole (help keep center front and back). Did the same with the .75” hole for the steel tube. Both batteries for drill worn-down – had to quit for the day.
