Brief Description: Dimpling the right inboard bottom skin
Before drilling the hinge I want to make sure everything is positioned correctly. I went a head and dimpled the skin. I clecoed it on the wing together with the outboard skin. I cut down the hinge to length and set the hinge up for drilling again. The fit was much better this time, I think when things get riveted it will tighten things up.
