RV-7 Some assembly required
Date:  5-31-2015
Number of Hours:  6.00
Brief Description:  Landing light
Started with riveting the 6 remaining rivets on the right leading edge. Did a final rivet inspection before mounting it on the main spar. Was not happy with the with and decided to realign the wing stand.
Had to take it off the spar in any case to cut out the hole for the landing lights. There is a template, but I think I measured it 6 times before actually starting the cutting.
Just for fun I riveted one leading edge rib to the spar. It went OK, but one of them pushed the flange a little. I’ll sleep on it and decide what to do tomorrow.
Using template
Using template
Cutting
Cutting
Sanded and polished
Sanded and polished
