Matched drilled the wing walk plate to the top skin with #41 to allow for reaming to the ribs. Mounted skin on wing and match reamed the top skin to the RW skeleton.
Had a look at the rib to spar holes in the leading edge rib and decided to scrap it. It's only $30 for a replacement part, but worth a million in the satisfaction of not going under the tolerance for edge distance.
