Brief Description: Fuel tank fitting and baffle fitting
Re-aligned the main spar. Strapped down the fuel tank, now the fit is perfect. Proceeded to drill the tank to the joint strip, then the most inboard tank rib to the baffle and z-bracket. Removed the leading edge and drilled the outboard tank rib to the baffle and z-bracket. Unclecoed the tank skin from the baffle and the two drilled ribs, leaving baffle and the two ribs clecoed to the spar. Drilled the remaining z-brackets to the baffle. All holes lined up according to plan, with enough space for the tools (pull rivet etc.). Finished off the week-end by deburring and dimpling the tank joint strip for #6 screw. Next up is to drill for nutplates.
