Brief Description: Started left wing ribs deburring
Riveted the rear spar left stiffer plates. Dug out the wing ribs, distributed them to left and right wings and deburred 1 out of 24 wing ribs (then there is the leading edge ribs to deburr as well......). A light touch with a vixen file, then the deburr edging tool, then normal sandpaper (220 and 600 grit) seems to do an OK job as the scothbrite wheel can't get into the nook and crannies anyways. I'll plan to do a couple every evening
