Brief Description: Fitting the HS 4 - Second set of holes
I continued with the rear spar and used a #30/#12 step double fluted drill bit to upsize the #30 pilot hole to the final #12. This also allow for the drill block to be positioned and clamped in position.
I inserted AN3 bolts into the upper holes and tighten with nuts and repeated the process for the lower holes.
