RV-7 Some assembly required
Date:  9-11-2018
Brief Description:  Final drilled the engine mount
I final drilled the engine mount. I used bushing to positioning it with the 1/4" bolts I used for the rotisserie and drill out one by one to 3/8". I then used HW 3/8 bolt to temporary bolt the mount on to enable testing for interference of all the things that get bolted to the firewall.
Engine mount... mounted
