RV-7 Some assembly required
Date:  10-16-2017
Number of Hours:  1.00
Brief Description:  Riveted side skirts
Riveted side skirts. All but 3 rivets have easy access and are easy to rivet. I used a squeezer to get a uniform shape of the manufactured heads along the side.
The beads looks as good as I was hoping for. I did need to scrape of small excess, as the exceeds were on non primed areas it can be removed with a finger nail.
Left side bead cleaned up
Right side bead cleaned up
Uniform look from inside
