Brief Description: Used the latch install template for lock install
I determined I wanted the ability to lock the canopy. It's more of a nosy deterrent and safety precaution than a security issue. During the latch install a template was made to determine location of the openings. I used the same template and extended it to determine where to best locate the lock cylinder. At the same time I could design some lock bolt guides, keeping it in place both in locked and unlocked positions.
I transferred this location onto the fuselage side skin. This is a place were you do not want to make any mistakes as they are very difficult to repair.
The hole follows the shape of the cylinder and has vertical side to avoid any rotation of the cylinder.
