I sanded yesterdays micro and also checked out the glare shield surface for evenness. There are low spots that require filling as the surface is uneven. I used an angle to find the uneven areas and marked them up. Then I mixed up epoxy and micro and started filling the uneven areas and used an angle to squeegee the mix out.
