Made a new tie in bracket as the pre-drilled provided put the holes to close to the edge. I basically copied the hole pattern except the lower row and I also made it oversized so I can trim it for proper edge distance.
First I match drilled the bracket to the HS spar with #30, they will later be upsized to 3/16 for AN3 bolts.
Second step was to match drill the middle holes from bracket to spar and the lower from spar to bracket. All #40, later I will ream up to #30. But that is for another day.
