RV-7 Some assembly required
Date:  2-11-2017
Brief Description:  Static line install and routing
Installed the static line, at least the rear part. Tested the routing though F-705 and F-704. It's great to have the rotisserie, makes jobs like this easy. I am planning to make something to hold plastic bushings in place in the F-704 area to avoid chafing and wear/puncture of the static line.
From static ports
From static ports
Through F-705
Through F-705
Above F-704
Above F-704
