RV-7 Some assembly required
Date:  9-15-2018
Brief Description:  ANL fitting
I will have two ANL fuses, one for each alternator. I got some ANL holders from B&C and manufactured some 1/8" copper strips to provide connection to the mater relay. I bent them a little as the relay output is nearly in the same plane as the ANL connection bolts.
ANL holders and connections
ANL in place
ANL in place
