RV-7 Some assembly required
Date:  8-23-2018
Number of Hours:  1.50
Brief Description:  Started the finishing F-705 riveting
With the top skin in place, I could complete the riveting of the F-705 bulkhead. These rivets is the ones that binds together the beefy angle (F-705G) with the hardware for the canopy frame. Either the skin rivets in that area have to be pulled rivets or you have to wait with the F-705G riveting until the skin is riveted. I selected the latter.
I did mostly all of them, but there are a few I cannot get to because the forward deck is blocking access. I guess I should have waited with the decks.... now I have to find away to get rivet access or use bolts.
F-705 riveting
F-705 riveting
Forward deck tie-in
Forward deck tie-in
Limited access
Limited access
