The second try went great. The secret is to avoid any twist in the first place, but just in case: don’t drill all the holes in the tip for the rib and to not countersink the tip. You might need to reposition the rib and close the old holes when de-twisting the tip. If you end up with no twist it’s just a matter of drilling the remaining holes.
