RV-7 Some assembly required
Date:  7-19-2018
Brief Description:  Wingtip trailing edge adjustment 2
I split the tips to adjust the twist. The only way to move the eh... tip-tip, is to split the outer portion about 1/3 of the cord.
I guess I could made more attention to twist when I drilled it (instead of the flange), but I think in any case it would have moved a little when riveted.
Before, the tip-tip swayed to the right.
I used two angles to hold it in place. I will glass it in position tonight.
Removing twist
Removing twist
