Yesterdays rudder/VS fairing glassing went great. Instead of sanding in place, I took the rudder/VS fairing off as one piece. It was pretty easy to make new curve, most of the added material was sanded off, just leaving what was needed for the smooth transition. I then marked and cut the rudder/VS combination back to the two separate pieces. The curve is now much nicer, but I still need to add some material to the edges for better definition.
