RV-7 Some assembly required
Date:  6-3-2018
Brief Description:  Wing tip hinge
Drilled the hinge to the wing tip. First I match drilled the -4 hinge. I then measured from the match drilled holes to the center of the -3 hinge and transcribed that line to the wing tip. I copied the positions from the first row of holes to the transcribed line. Last stage was to match drill the -4 hinge.
Afterwards I did some small trimming of the hinge and started to cut off the flange of the wing tip. The cut off will be used as a spacer when the -4 hinge is riveted to the wing skin.
I clecoed it all together, lubed the hinge ping and mounted the wing tip. It went surprisingly well, strangely enough the top hinge with more curve to it went easiest.
Measuring to center
Measuring to center
Transcribed to wing tip
Drilled
Drilled
