Drilled the left wing tip to the wing. Having the foam in place made the setup pretty solid. In addition to the pre-punched holes, I added one extra hole between each pre-punched on the advice from other builders using the hinge method.
Up to now, I have only rough cut the tips in order to clear the ailerons. When I have them installed I will make the clearance according to Van's instructions.
