Brief Description: Installed the rear elevator pushrod
Installed the rear elevator pushrod, set the length by clamping the elevators in neutral and the bell crank locked in vertical position with a 3/8 socket. I also checked the stick forward/aft alignment. It leans forward 10 degrees, so I need to elongate the forward pushrod a little.
Apart from that the action was smooth, no binding and no strange sounds.
