RV-7 Some assembly required
Date:  4-21-2018
Number of Hours:  1.00
Manual Reference:  SB 14-01-31
Brief Description:  SB 14-01-31 - 2
The next step in the SB 14-01-31 is to make the angles for the flange replacement. For the RV-7 they have a angle less than 90 deg. One side is also slightly oversized to facilitate positioning.
The new added stiffener have some pre-drilled holes, that is the new holes. The existing spar holes will be positioned between these hole. This require trial fitting and mark-up of the holes.
I figured out the best fit was when I drew a centerline through the top row of holes, then measures 12/32 from the edge and lined that up with one of the existing holes in the spar. This way ended up with proper edge distance for most holes.
Angles for flange replacement
Positioning the stiffeners
Marked existing holes
