RV-7 Some assembly required
RV-7
Fitting the HS 4 - Finishing up
With all 4 rear bolts in place, I located the two last front bolts 27/32" inboard from the two first.
These ones required an angle drill and short bits with no possibility of drill block use.
It went OK and the HS is now bolted in place.
HS finally fitted
RV-7 Home
2084
300
Finishing
103
211
782
Practice
Training
627
Workshop
Workshop and Supplie
