RV-7 Some assembly required
Date:  4-5-2018
Brief Description:  Brace for pitot wiring and stall warning wire
Before closing up the wing there are a few things I need to do.
- Securing the pitot heat wiring
- Securing the stall warning wiring
The stall warning was easy as it is a single wire. The pitot heat is a bunch of wires going to and from the regulator unit. I didn't want anything close to the aileron bell crank so I ended up making a brace in the next bay over.
