RV-7 Some assembly required
Date:  3-31-2018
Number of Hours:  3.00
Brief Description:  Trim tab III
Finished the trim tab III. I got 2 new skins from Vans just in case, but I aced it at the first try, mostly because I had the failed one as template.
I made sure the alignment was correct by using angles and a #30 drill bit.
Aligning the trim tab
Drilling hinge
Drilling hinge
