RV-7 Some assembly required
Date:  2-11-2018
Number of Hours:  4.00
Brief Description:  Decks in baggage area
I saw a local flying RV-7A slider a few years back with decks in the baggage area. I thought it looked great and got some RV-6 decks from Vans as they are undrilled.
It took a little careful measuring and it took a bit of tinkering, but it was easy to make the cut-outs for the aft fuse bulkhead and the hardware at the F-705 position.
I selected positions for the rivets and match drilled the existing bolt holes for Almost RV-14.
I will have to wait with the riveting until after the skins are in place as the deck limits the bucking access for those.
Fitting in place
Fitting in place
Drilled to longeron
Drilled to longeron
All done, fits great.
