RV-7 Some assembly required
Date:  1-19-2018
Brief Description:  Almost RV-14 install - 3
Before the cross bar can be drilled the angle needs to be trimmed to avoid interference.
I noticed that the crossbar had some sideways movement. I marked the far left and right and made a mark at the mid point so the bar could be centered. This way the bar will be centered and edge distance will be assured on both sides.
Trimming the angle
Trimming the angle
Determine position
Determine position
Marked for positioning
