RV-7 Some assembly required
Date:  12-22-2017
Number of Hours:  1.50
Brief Description:  Cut and drilled the elevator pushrod
Cut the elevator pushrod to length according to drawings and laid out the hole pattern for the threaded rod end. This is easily done by using a piece of tape around the circumference. Take it off and marked the number of desired holes and then put it back on the tube. I drilled using #40 first and used the step reamer to make them all #30.
