RV-7 Some assembly required
Date:  11-4-2017
Number of Hours:  1.50
Brief Description:  Started new latch bearing
I was pleased with the operation od the secondary latch handle. I had copied another builders spring loaded ball mechanism in order to keep the handle in position and avoid locking me out. I couldn't get it to work, but I found a nice part at McMaster Carr that could work (5901A36). It requires a larger delrin block because of it's length. That is no problem, I have delrin stock, drill press and I am building a freakin airplane. I can do this !
Ball-Nose Spring Plunger
