Brief Description: Installed canopy latch lug and guides
Positioned and drilled the latch lugs. I started with one #30 hole and tested the grip from the canopy latch. It needed a tiny adjustment (up) which was accomplished by drilling the second #30 in the new position. The first hole was then enlarged and then match drilled to the frame.
The grip is a little to tight, but that can be fine-adjusted by filing the latch itself.
With the latch lugs in place I drilled the delrin guides in place, deburred, mounted the guides in pace and called it a day.
