RV-7 Some assembly required
Date:  8-1-2017
Number of Hours:  2.50
Brief Description:  Filling canopy gaps
Mixed up some epoxy and cotton flox and added some pigment to see how well the pigment works. I'll use the same type of mix when glassing the canopy so any practice is good.
I stuffed it in there until it oozed out on the other side. Then I rough shaped it to avoid too much sanding tomorrow.
I ended the evening by spot painting the panel angles. Overkill, yes, but that's how I roll.
Left side
Left side
Right side
Right side
