Brief Description: Z-brackets, fuel tank deburring, stall warning
Attached the z-brackets to the spar. Deburred the remaining left fuel tank ribs and skin edges. Assembled the stall warning device. Test fitted the fuel tank to the spar, not an even seam between leading edge and tank, need to re-check the spar alignment (twist and level) and I need more straps.
